24-11-2015 #5
Hi, welcome to the forum! I'f you're thinking of mostly machining wood then I'm guessing that 95% of the time you'll be cutting at full extension. This is going to create one hell of a lever with your current design of gantry and Z axis. I'd be inclined to think about making the gantry shorter and having some sort of adjustable table so that when you do want to cut thick materials (probably the 5% of the tine it's used) you can lower it.
The Following User Says Thank You to njhussey For This Useful Post:
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
Using stainless steel tube for linear bearings
By shoeswith in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 31-07-2017, 03:19 PM -
I need to build a tube profiling machine
By Paulgy80 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-04-2014, 12:58 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
