thanks Jazz,
appreciate the advice re. plasma
with the high Z, I know what you mean it is a real weak point- ill reduce this
I would however, like to keep the option of having large material fit under the gantry, (300mm)
if i reduce z travel by 100 mm and bring material up with a raised bed do you think the machine is more solid or still compromised by gantry height?
cheers ben
26-11-2015 #2
Yes provided you keep the Distance or Z axis extension short then you won't have a problem. But this is still a slight compromise on overall machine stiffness because you still need to create that height in the first place which weakens the machine to some degree compared to short stubby design but it is the lesser of two evils I suppose.!
For machines like what you want then having a moving bed is best option because it gives the best of both worlds but keeps the machine stiff compared to just packing the Bed up.
BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
By grain_r in forum DIY Router Build LogsReplies: 130Last Post: 27-01-2023, 06:47 PM -
Using stainless steel tube for linear bearings
By shoeswith in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 31-07-2017, 03:19 PM -
I need to build a tube profiling machine
By Paulgy80 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 13-04-2014, 12:58 PM -
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM
