  1. #41
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 15-12-2024 Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    A recent project - mother of pearl 'Punisher' fret marker inlays for a local guitar maker. They take bloody ages..! (But look alright...)
    The smallest end-mill I used was a 0.2mm on the higher markers - thankfully I only broke the one. Very slow feeds - 1.75mm/sec and a 0.75 DOC.
ID:	17282Click image for larger version.
ID:	17283Click image for larger version.
ID:	17281Click image for larger version.
    Once installed, the pockets in the pearl will be black-epoxy filled and then sanded back flush to the ebony fingerboard. Looking forward to seeing this coming together - glad I'm not sanding that ebony board, though... For reference - the pockets in the ebony were cut with .08mm clearance - the markers seem to fit very nicely, although I didn't get to push 'em in all the way...
    Wal.
  2. #42
    Very nice Wal - I'm about one spare evening away from trying to cut the rosewood finger boards on my Jaguar project and will be using a 0.5mm end mill for the fret slots (fret spacing seems to be made for CNC work IMHO provided I don't snap the tool). Your work makes me think I should do something more ornate than dot inlays....
  3. #43
    Wal's Avatar
    Hi Washout,
    Yeah I've followed that neck project a bit. Nice seeing it in progress. Yes, you should definitely try something different with the markers! Easy to say though, as I'm not sure what I'd do for my own build... Will your 0.5 cutter have enough depth for cutting the slots or are you profiling the radius before you cut 'em. I ask as I noticed that the slots were cut quite deep on this board (by luthier) and I needed a long necked 0.5 cutter to do those perimeter grooves around the pockets...
    Wal.
    Sent from my HTC One M9 using Tapatalk
  4. #44
    You did 0.2mm OMG that is insane. I did play with sinking a 0.5mm rib cutter in to aluminium. I couldn't get any kind of finish at the bottom but I was thinking I had done well. Right up to the moment when I saw you had done 0.2mm. Ballpoint for scale
ID:	17291   Click image for larger version.
  5. #45
    Wal's Avatar
    Hi Robin - yeah, but the 0.2 was in mother of pearl... The smallest I've tried in aluminum is 0.4 - pics below. Slow going but the quality seems to hold up alright.
    Oops, probably heading a bit off topic...
  6. #46
    Wal's Avatar
    Back on topic - I came across this guy the other day. Wonderful viewing! Excellent craftsmanship, great gear and a first class result.
  7. The Following User Says Thank You to Wal For This Useful Post:
  8. #47
    Wal, I know of Gough previously, if you have a look in his videos he's got a time lapse of his renovating the MC he uses.
    .Me
    .Me
  9. #48
    Wal's Avatar
    .Me
    Hi Lee, yeah - the old Fadal? Nice video that too. His workshop's tidy enough to rival McLaren's...
  10. The Following User Says Thank You to Wal For This Useful Post:
  1. Moment of Inspiration
    By JoeHarris in forum Computer Software
    Last Post: 04-11-2013, 08:38 PM
  2. Can't reply to a thread
    By Washout in forum General Discussion
    Last Post: 24-10-2012, 06:56 PM
  3. Thread Tapping?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 04-05-2012, 04:51 PM
  4. Thread diameter
    By Daniel in forum General Discussion
    Last Post: 23-02-2012, 06:18 PM
  5. Ideas and inspiration....?
    By Tom in forum General Discussion
    Last Post: 10-08-2010, 01:09 AM
