    Just a quick question, I have my AM882 setup as follows.
    Alarm is set to active low and Enable is set to active high.
    The question is if the AM882 is not receiving an enable signal then it appears to trigger the alarm. Is this correct as manual only states that the alarm signal will only trigger on the following errors "Alarm signal: OC output signal, activated when over-voltage, over current, under-voltage, phase-error and stall-error protection."
    If i supply the Enable contact the red alarm led stops flashing, and as soon as i cut power to the enable it starts flashing again.
    Although ive not got a motor connected so could it be a "Phase Error Protection" alarm thats actually triggering?
    Regards
    Trev
  1. Wiring up the Alarm output on Leadshine AM882
    By Shinobiwan in forum Motor Drivers & Controllers
    Last Post: 01-08-2017, 02:07 AM
  2. Need to slow down a signal due to Safe Torque Off alarm
    By corkcnc in forum General Electronics
    Last Post: 04-06-2014, 11:35 PM
  3. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  4. Mach3 and its enable function
    By GeorgeD in forum Artsoft Mach (3 & 4)
    Last Post: 12-07-2010, 09:47 PM
  5. +5V TTL Signal
    By NC-Joey in forum General Electronics
    Last Post: 12-08-2007, 02:46 PM
