Thread: Hybrid Mill Design
30-11-2015 #9
Hi Chaz,
If you look at my design the side plates are braced back to the main Y axis assembly with effectively triangular structures. There is also a closer plate (see Y axis picture) to create a local box structure, which also provides stiffness for the Y ballscrew to connect to. On your design some triangular bracing pieces could work with a notch / clearance area at the inside corner to clear the ballscrew.
I thought alot about the spindle clamping and problems with keeping the rails aligned. In the end the spindle clamp is quite small, and the plate on the bottom surface is fixed (the transparent piece in the last picture), plus the front plate above the spindle is also fixed. This should keep the rails aligned whilst adjusting / clamping the spindle. Look at the last picture I posted for my thoughts on how to do it.
I drew loads of single and twin Z axis ballscrew arrangements but could not get a compact package with twin screws, so after agonising over it went back to single which has the smallest offset from the centre line I could achieve.
As for the Z axis bearings on the dmg machine - I don't know this for a fact but I can't see any Z rails so my conclusion is that is runs on a finely ground flat surface on the hexagon faces - bit like the ways on a mill / lathe but flat and trapped on all sides. You can see some sort of pre-load screw(?) or oiling point so perhaps it also has a film of high pressure oil in there like an engine crank/big end. Really just guessing here so would welcome thoughts from others on this. Either way, probably not a DIY solution.
Hybrid Stepper Servo
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 08-06-2015, 12:41 PM -
Interesting Mill Design on Hackaday
By epninety in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 01-03-2014, 05:10 PM -
Building a hybrid CNC mill. Need advice and recommendations
By oldmam4m80s in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 16-08-2013, 07:11 AM -
Hybrid gantry
By routercnc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 17-04-2012, 08:09 PM -
Small Mill very early design stage
By leadinglights in forum Milling Machines, Builds & ConversionsReplies: 29Last Post: 15-06-2010, 01:05 AM
