Page 2 of 2 FirstFirst 12
    If you can use a 4kw VFD then you have a 3~ mains. A normal 1~VFD have a maximum of 2,2kW.
    Thats the maximum, what your 13Amp power socket is capable. The VFD can have more power then the motor, but should be in a similiar power range, 1,5 to 2 * the Motor is ok but not 5 times.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 5 Days Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by uli12us View Post
    Thanks. Understood. I am running my mill from a 32A socket.
    Chaz's Avatar
    So, wired to Delta. 30uF cap, doesnt spin up, just turns slowly.
    Connect a 300uF cap, instant spin up. Takes full load, can block the vacuum pipe with my hand, it just keeps going.
    The only thing was that motor got hot very quickly. I didnt have the cowl structure on it so that meant no real cooling. It got hot very quickly however.
  1. 3.0Nm stepper from Zapp stopped working / faulty
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 10-05-2017, 08:59 PM
  2. Replies: 2
  3. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
  4. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 11:33 AM
