    Chaz's Avatar
    Not sure where to post this.
    I bought a Becker VT 4.25 Vacuum pump on ebay as it was 'faulty'. This is to 'power' my vacuum table.
    I was hoping that it was not really faulty and that I may be able to repair it. I didnt pay much for it, so worth a chance. The machine came without the faceplate but following the manual below, its a 3 phase motor that can be run using single phase. The motor is 0.9KW or around 1.1HP.
    http://www.ecovac.com.tw/pdf/rotary_.../oi_vt4.25.pdf
    After messing around with starting capacitors, I manage to get the machine to spin up. It runs up to full speed however whenever I add any load, the machine stalls. I found that the wiring wasnt 100%, so I rearrange the wiring. I measure around 6.7 Ohms across 3 distinct coils which seems to imply that the motor is fine.
    So, as the motor cannot take much load before it stalls, is it faulty? Could it be too large to run on single phase (Im using a starting cap, no running cap and it stays in circuit all the time, no logic to remove it from the circuit).
    Im tempted to buy a 4KW spindle and VFD although I dont strictly need it. The VFD could be used to see if the motor works on 3 Phase. These pumps are expensive and if it works for my vacuum table, it will be a bargain.
    Thoughts?
    If you start the motor without load you need only a running cap, it should be in the range of 35µF. But without running cap, the motor can't run. But you must run the motor in triangle instead of star connection.
    Instead that you can use a VFD, but this part is much more expensive.
    Chaz's Avatar
    Quote Originally Posted by uli12us View Post
    So I can get it to run with a starting cap. It goes up to what sounds like full speed but has no torque. This does sound like a common issue with a 3phase motor 'single phases'.
    Chaz's Avatar
    Are you saying it should run in Delta with a 35 uF cap for starting?
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Chaz There is a drawing on the pdf you linked to with a cap does it say the value of the cap? How exactly do you have it connected.
    Chaz's Avatar
    Nope, no value.
    I dont have the nameplate either.
    The guy at Becker UK told me these motors cant be run single phase. Odd, the drawing shows it can or should be possible. Unless there is a 3 phase and single phase version which is different.
    Nope, no value.
    OK Have you wired it the same as the plate on the motor
    Chaz's Avatar
    The motor didnt come with a name plate.
    Im fairly sure its a 3phase motor, not 'made' for single phase.
    OK But are the terminals laid out like in the 1ph picture on the pdf with links in. and can you see 6 wires from the coils connected to them?
    Chaz's Avatar
    The wiring was a Star connected 6 wire system. That said, when I checked the pattern, it didnt match the drawing in the document, someone could have messed with it.
    Ill try delta connection tonight and see if that helps before considering buying a VFD (£120 ish for a 4KW unit that can run the 4KW spindle later).
  1. 3.0Nm stepper from Zapp stopped working / faulty
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 10-05-2017, 08:59 PM
  2. Replies: 2
  3. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
  4. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 11:33 AM
