Page 3 of 3 FirstFirst 123
  1. #21
    Thanks guys.
    This is great. I understand it now. Basically, I am adjusting the ballscrew tighter by the tab nut and tab washer!
  2. #22
    i2i's Avatar
    Not really, you're adjusting the preload on the pair of angular contact bearings in the green block that fixes the ball screw to the table.
  3. #23
    Quote Originally Posted by i2i View Post
    ...the blue ones in the illustration below. I was trying to figure that out.
  4. #24
    i2i's Avatar
    the drawing doesn't really represent the action, but that's where it is.
  5. #25
    You cannot adjust the ball screw bearings, they are what they are.
    When you have an angular contact bearing in your hand the middle wobbles back and forth.
    So what your almost doing when you have a pair is pulling the middles together to get rid of that play.
  6. #26
    Quote Originally Posted by stallone View Post
    This drawing is not correct as it is not showing the inner part of the AC bearing
  7. #27
    The spacer should be on the inside race so it shows the lock nut squeezing the outer races together....if that's how its assembled? I thought they normally had the lock nut on the inner race with the ballscrew also on the inner race and the outer races locked in position?
    Neil...
    Build log...here
  8. #28
    The tab nut tightens the inner race of the bearings not the outter
  1. CONVERSION: Denford Triac VMC with ATC Conversion / Fix
    By Chaz in forum Conversion Build Logs
    Last Post: 07-08-2017, 03:41 PM
  2. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  3. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  4. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  5. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
