05-12-2015 #7
Depends on the figure your quoting is that 1000 PPR or 1000 x .? . . ie 200 x 1000.
The AM & EM have Max Stepping of 51200 PPR or 256x (200 x 256) They can be set in 2 ways Via Preset values With Dip switches on the drive Ie 400,800,1600 etc or using software in which case you can set to any Ms amount you like.
This parameter Configurabilty esp regards Resonance is what sets them apart from drives like Gecko's etc that leave you stuck with there preset values. In practise 99% of the time you don't need to change any of these parameters and software will Autotune it's self to the motor but in cases where you do they are life savers. Or if you want to tweak the machine to gain the best possible performance from the motors then you can if desired.
Also Don't think of Micro step as increasing Resolution that's not it's main function. It's more useful for motor Smoothness at lower speed. Having the Ms set too high just stresses the Pulse generator for very little to No gain in performance/resolution.
Having Ms set above 16x or 3200ppr is pointless with normal steppers has they won't resolve any hgher than this. It also has a Negative affect on Torque at high speed.
Ms of 8x (1600ppr) is more than good enough for any stepper system using Hybrid steppers and will give reliable stable system. If you want more resolution the either apply a ratio or fit screws with smaller pitch. Trying to Use High Ms will only make your machine unstable and lower peformance.Last edited by JAZZCNC; 05-12-2015 at 02:43 PM.
CONVERSION: Denford Triac VMC with ATC Conversion / Fix
By Chaz in forum Conversion Build LogsReplies: 240Last Post: 07-08-2017, 03:41 PM -
FOR SALE: Denford Triac CNC PC
By ricey3 in forum Items For SaleReplies: 6Last Post: 10-01-2017, 01:39 PM -
Help Denford triac p.c.
By mikeulike in forum Denford MillsReplies: 3Last Post: 02-06-2015, 03:59 PM -
eBay: Denford Triac with Mach3 Conversion
By large519 in forum Items On eBay UKReplies: 0Last Post: 29-04-2015, 05:34 PM -
CONVERSION: Denford Triac Mach3 conversion
By rnr107 in forum Conversion Build LogsReplies: 11Last Post: 23-10-2014, 02:44 PM
