  1. they were 3 phase actually, leadshine dont make 5 phase drivers.
    Quote Originally Posted by Gary View Post
    Ye had brain fart on that one Gary for some reason I had it in mind they where 5 phase motors but on reflection it was obvious given U V W wrote on top of drive. .
    Don't misunderstand me, I want to change the control Unit of My Boxford machine. The Emco with the
    strange Motors should be original. And only for the Boxford I need eventually the 2000 µstep from a
    leadshine driver.
    So I was able to get a little time with the machine this last weekend, but not much. I started to test the backlash on the Triac but I think I was doing it wrong. I am too inexperienced!! However, I did notice the end of the leadscrew (I think it is that) with the pulley, it moves back and forth approximate 2 degrees before engaging. I am not sure if this tells me anything.
    Pic below of the end of x-axis pulley.
    I did have time to measure the position of the stepper pulley on the shafts for the new stepper. The new steppers for x and y are much larger than the originals, but they fit!
    Thanks for your help,
    --mike
    you can easily get rid of backlash on a triac by just tightening the tab nut on the end of the table. getting the right preload on the bearings can be pretty tricky.
    ive gotten he backlash on my triac down to 0.02mm, which im pretty happy with.
    Hi Andy,
    Where would I find this tab nut?
    Quote Originally Posted by andy_con View Post
    ...and what steps would I take to adjust it correctly. ...without screwing things up!
    Thanks,
    --mike
    you remove the pulley to reveal the tab nut and tab washer.
    fold down the tab washer leg which stops the tab nut from rotating, then you can tighten tab washer.
    only way ive found to do it, is to tighten put back together and check back lash, if still there remove everything and tighten even more. back lash should be checked using a test dial indicator
    you remove the pulley by undoing the grub screw located in between the teeth
  1. CONVERSION: Denford Triac VMC with ATC Conversion / Fix
    By Chaz in forum Conversion Build Logs
    Last Post: 07-08-2017, 03:41 PM
  2. FOR SALE: Denford Triac CNC PC
    By ricey3 in forum Items For Sale
    Last Post: 10-01-2017, 01:39 PM
  3. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  4. eBay: Denford Triac with Mach3 Conversion
    By large519 in forum Items On eBay UK
    Last Post: 29-04-2015, 05:34 PM
  5. CONVERSION: Denford Triac Mach3 conversion
    By rnr107 in forum Conversion Build Logs
    Last Post: 23-10-2014, 02:44 PM
