  1. #6
    Sounds to me like you may be using the wrong Input number or not set the port number or something then because mach isn't seeing the pin state change.
    If you had the correct pin number then toggling the Active state would work no matter if your inputs used pull up or down resistors.
    Not using the correct pin/port number or a Blown input is the only thing that would do this. The fact Mach resets when you toggle Lo active just means your tricking mach into thinking E-stop is there. It's basicly watching that input to go high which never will because you have the wrong Input number or it's dead.!
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. AM882 works with Protune - but not with the ZPA5-INT BOB
    By badgerman in forum Motor Drivers & Controllers
    Last Post: 01-09-2013, 09:44 PM
  2. TOSHIBA THB6064AH Updated Active IC
    By lihaijiang in forum Manufacturer News
    Last Post: 09-04-2012, 03:43 AM
  3. Replies: 9
    Last Post: 03-04-2011, 01:52 AM
  4. How Rotary Broaching Works
    By steve3d in forum Tool & Tooling Technology
    Last Post: 18-01-2011, 03:17 AM
  5. My CNC WORKS...
    By emboss.shop in forum Metalwork Project Showcase
    Last Post: 30-09-2009, 06:04 PM
