  1. #4
    Quote Originally Posted by amd7000 View Post
    Yea, the estop has nc marked on it. If I adjust to the mach3 settings to low active it just says e stop requested even though the led for estop only lights up when the estop is pressed. I haven't got a clue what's going on.
    Thats what it should do.? The LED should only come on when E-stop is pushed in. It's informing you that an E-stop occured.
    When you release the E-stop button the LED goes OFF and Mach will then allow Reset.
    NC means the Circuit is closed before the E-stop is pushed. So when pushed the Input you used for E-stop is pulled Low or high and that's why you use Active Low or high mach knows when that input goes Low or high and E-stop is active. The LED comes on to inform you.
    This does depend on your BOB Input some are Pulled High or Low with pull up/down resistors in which case you just change the active state to match.
    Don't trust the markings test it.! . . . When released you should get continuity between terminals if it's NC. When pushed there should be none.
  1. AM882 works with Protune - but not with the ZPA5-INT BOB
    By badgerman in forum Motor Drivers & Controllers
    Last Post: 01-09-2013, 09:44 PM
  2. TOSHIBA THB6064AH Updated Active IC
    By lihaijiang in forum Manufacturer News
    Last Post: 09-04-2012, 03:43 AM
  3. Replies: 9
    Last Post: 03-04-2011, 01:52 AM
  4. How Rotary Broaching Works
    By steve3d in forum Tool & Tooling Technology
    Last Post: 18-01-2011, 03:17 AM
  5. My CNC WORKS...
    By emboss.shop in forum Metalwork Project Showcase
    Last Post: 30-09-2009, 06:04 PM
