    I had a look at the Zapp website and the documentation there doesn't mention the estop pin. However I then loaded up the .xml file provided and ran Mach3 with it and it is set to port 1 pin 10 active low is a red cross.
    So I have doubt that you are using the right input pin.
    Rob
    There isn't a special E-stop pin any Input will work but Mach needs to know where to look for it and I think he's telling mach to look in wrong place.
    I know that Dean, but if you look at the Zapp site, there is a manual for the board. It shows a picture of the board and one input has a printed label 'ESTOP' with an arrow pointing to it saying P15. However the .xml file Zapp supply uses pin 10. This does rather suggest to me there is something awry. I would certainly try changing Mach3 to use pin 10. In the Zapp copy of the Chinglish documentation it says use Mach3Mill profile, which is also pin10 for Estop.
    I also think that Mach3 diagnostic screen could have better labelling of the LPT indicators.
    Cheers,
    Rob
    Yes i see what your meaning now Rob but I wouldn't put much stall in that because they could have just used Pin for E-stop at the time.?
    This is the problem Chinglish manuals they leave you guessing but in this case it's easy really just keep entering pin mubers between 10 -15 in mach's E-stop Input.
    Amd What pin number did you have in entered.?
    In scientific terms it is known as empirical determination, My dad used to say 'suck it and see'
    Sorry for the late reply guys. Been in bed with a dodgy chest infection, no energy to do anything, i'm sure its the damn ecigs.....
    I set the estop to port 1 and pin 15 as stated in the manual. It was set to pin 10 in the first place when I loaded the xml and before fitting the estop. I cant remember if I tried it with pin 10 first. Will try when I'm feeling better. Thanks for the help. Really appreciated.
    Just had a thought - there is a program called LPTTEST you can download for free, it tells you what the BoB is sending to the machine, so you will know what pin Estop is on and what state it is in when normal / pressed. Then you will know what to set in Mach. I built a tester some time ago with Leds and an input socket and a output socket - but I can't find it now.
    Cheers,
    Rob
  1. AM882 works with Protune - but not with the ZPA5-INT BOB
    By badgerman in forum Motor Drivers & Controllers
    Last Post: 01-09-2013, 09:44 PM
  2. TOSHIBA THB6064AH Updated Active IC
    By lihaijiang in forum Manufacturer News
    Last Post: 09-04-2012, 03:43 AM
  3. Replies: 9
    Last Post: 03-04-2011, 01:52 AM
  4. How Rotary Broaching Works
    By steve3d in forum Tool & Tooling Technology
    Last Post: 18-01-2011, 03:17 AM
  5. My CNC WORKS...
    By emboss.shop in forum Metalwork Project Showcase
    Last Post: 30-09-2009, 06:04 PM
