    Thanks copwell
    it may still have the same prob as I/o are automatic. I'm going to try to update the graphics and see what happens. Then put win pc on and see wot happens! Ps im on 32 bit vista at the mo. But if I change some cad stuff won't work on workshop computer
    f me wrote this twice timen out and wouldn't copy. STOOPID program
    gaham
    Don't bother changing to 64bit OS because Mach3 PP driver won't work with it. 32bit only.
    Do your self a favor and don't waste any money buying PP card just save then money and put towards motion control card.
    When you do get the card working find the i/o address in resource manager and then in mach make sure you enter 0X(Zero) then address.
    Duh ! Of course. I forgot that, probably because I have been up till 2 AM farting about with my own machine, replacing the BoB after the last one 'failed to proceed'. In the process of doing that I checked out the wiring and eventually found a broken earth wire that was causing all sorts of faults.
    Dean - if you want a laugh - I was using the continuity test buzzer on my multimeter and getting annoyed that I couldn't find continuity on circuits I thought were OK. Then I realised that my multimeter had auto shut down.
    If you want another laugh - I am replacing a BoB, when I have a CSMIO IP-S new in a box on the shelf (destined for a better machine than this MD THING.
    Cheers,
    Rob
    Won't laugh because I've got one that does the bloody same.!!. . . To be honest can't believe it's still alive because I've obliterated tools for less. . .Lol
  5. #15
    Lives in Plymouth, United Kingdom. Last Activity: 16 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    So, it's not just me, then?
  6. #16
    I will hold my hand up as well.
  7. #17
    Me too....spent ages trying to work out why the relay wasn't closing the contacts....
    Neil...
    Build log...here
  8. #18
    i2i's Avatar
    omg you thickooos.......and me, oops
  9. #19
    well that's exactly what iv done it seems the PCI parallel card are rarely true ports and are usually jumped up usb devices it's the advice cnc4 you gave as well
    even if I could find one which will work with this computer, itt is 8 years old and may go pop! If it did I'd be in exactly the same situation again with a new computer!
    So waiting now for the motion controller to arrive- it's a lot of money for what is basically a dongle but I could have bought quite a number of lpt cards in the mean time im making the covers for the steppers!
    Yhanks guys
    Last edited by Cnc many; 11-12-2015 at 11:30 PM. Reason: Silly ....sub device... No usb device dyslexia rules ko! Olo---lol
  10. #20
    What motion controller have you gone for?
  1. usb - parallel
    By universally in forum Gantry/Router Machines & Building
    Last Post: 12-03-2015, 04:03 PM
  2. Mach3 ports and pin setup to match my control box
    By Sparky in forum Artsoft Mach (3 & 4)
    Last Post: 13-11-2014, 04:00 PM
  3. New Motherboards and LTP1 ports. (You might have one)
    By Mattbatt in forum General Electronics
    Last Post: 05-04-2013, 10:12 AM
  4. ports and pins for system4
    By Dan Brown in forum Motor Drivers & Controllers
    Last Post: 18-01-2010, 06:37 PM
  5. Ports and pins help ? mach 3
    By xchipx in forum Artsoft Mach (3 & 4)
    Last Post: 19-04-2009, 12:45 PM
