Thread: Parallel ports problems
06-12-2015 #3
I have a feeling that from Vista onwards LPT addresses followed a wider convention. Have you looked in your computer bios to see if an onboard LPT is enabled? If so you might want to disable it and try re-installing the card. 0x378 may then become available for your PP card.
First you could try setting Mach3 to EE000 or whatever value you have in the device properties. Mach3 uses LPT in a 'special' way.
Cheers,
Rob
usb - parallel
By universally in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 12-03-2015, 04:03 PM -
Mach3 ports and pin setup to match my control box
By Sparky in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 13-11-2014, 04:00 PM -
New Motherboards and LTP1 ports. (You might have one)
By Mattbatt in forum General ElectronicsReplies: 0Last Post: 05-04-2013, 10:12 AM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
