Thread: Thread milling shallow bind hole
Hello Komatias,
Thank you for your reply. I realize I am not on the direct road for success, with the following
small diameter, shallow blind hole, in 316 no less, limited knowledge and wanting to thread mill it. All that said I may have a go at it.
Steve
11-12-2015 #2https://emvioeng.com
11-12-2015 #3
11-12-2015 #4
Hi Clive
Tar very much for the thought. Your question is a good one. I was looking to remove them but that may only be if something fails and the job needs breaking down. I will not dismiss opening the hole up slight larger and getting out the epoxy. Thanks for your help and waves of thought!
Steve
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
Tips and tricks for shallow milling/ engraving ?
By Gasgasbones in forum General DiscussionReplies: 17Last Post: 11-01-2015, 09:39 PM -
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM
