    Quote Originally Posted by ba99297 View Post
    Dean the ladies often tell these words to the "small tool" owners in order to console them.
    Oh yes Vagelis this small "Tool" has been consoled many times and the pleasure was all mine. . .
    Nice to see you back and would be even better to see more progress.!
    Oh dear, I am not the only Greek on here any more. Vaggo, looking forward to seeing your cutting machine too.
    https://emvioeng.com
    Kingcreaky thank you for the files.
    Looks really nice. Is it 3100mm in the long axis? Are you bolting the plates to the vertical frame first and then weld the cross members in place or have them made before with the 2 plates attached and then bolt them to the vertical frames? Can I pre-drill plates and side members using a jig in a bench drill then tap then start building the frames or I will be way too off?
    Being new to CAD I spend the last 3 days trying o design a preliminary plan of the base. My main concern was to be able to design it parametrically so I can change most of it on the fly without having to redesign it again. So far it works well even though the design structure is like spaghetti code.
    The base steel tubing is 60x 60 x 5 and the lower grid is 60 x 40 x 3.
    The top right and left tubing would be bolted to the base for adjustment purposes if that is an extra benefit.Then epoxy leveling .
    Any suggestions where to source the Hiwin rails? CAD files for them?
ID:	16877Click image for larger version.
    Thank you all
    Any particular reason your using so many cross members? Just out of interest how far are they separated? Its certainly not a bad thing, the more the merrier I would think, however I think it would be significantly stronger in terms of deflection to have fewer cross members that where triangulated to the bottom rails rather than more with no triangulation. Having more would be beneficial though because it would support the sheet more evenly along its length.
    They are 311mm apart when the base is 2800 x 1650.I was thinking of having the lower grid of the base free for storing ply .
    Argyri,
    Looking good!
    The best place to get the Hiwin CAD models is http://www.hiwin.de/en/CAD_Configurator.html
    Most cost effective way to get the rails and carriages is to go east. I would suggest that you get carriages with preload so they do not have any slop, it adds a bit to the friction but worth the extra effort.
    In order to account for distortion etc I would suggest you build, level and then drill. A hand drill with good bits and a drilling jig like you describe is good as long as you make provision to straighten the rails afterwards. Have a look at installation instructions from HIWIN which is similar to this NSK one for ideas on mechanisms to align and adjust for straightness and squareness, if you haven't already done so.
    You could have the top sections on bolts but what would be the benefit if you epoxy level and drill afterwards? From our conversation it seemed that you were not thinking of moving the machine around so stripping it down is not needed. I would have thought that, should you crash the machine, you would need to readjust everything including the rails. In a rigid system, you will potentially only need to readjust the rails.
    Regards
    George
    Yeah that seems reasonable.
    I see a few things I would change but rather than put into words it's easier to show you. Most Should be obvious but ask if not sure.
    The reason for top rail being longer at each is to recover some wasted bed space plus makes machine shorter. Also allows gantry to ride past the end so can use end of machine for standing boards upright or fitting 4th axis across end if required. Long overhang would be rear short would be front.
Name:	front frame.png
ID:	16880Click image for larger version.
ID:	16881Click image for larger version.
ID:	16882Click image for larger version.
ID:	16883Click image for larger version.
Name:	top frame.png
ID:	16884Click image for larger version.
    Dean,
    Thank you very much for your help I really appreciated.
    Smart way to increase the cutting area and add future use(4th axis)
    Few questions and I think I am good to go.
    Steel tubing for the whole base 60 x 60 x 5 ? Do you agree on that?
    Length of the bed 2600 + 100 short overhang + 300 long overhang = 3000 total would that be o.k? Do the overhangs need to be braced?
    What are the spacing of the cross members and the top rail supports in your drawings? No dimensions so I can't calculate.
    Has anyone joined hiwin rails lengthwise let's say 1500 + 1500 to achieve 3000mm length. Is it doable for the home builder? ordering from BST automation 3000mm rails will make shipping cost way up.
    Hopefully I will be start building in the beginning of January.
  1. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 06:53 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. RFQ: Help needed to build my first machine NE Norfolk
    By Dorg in forum Projects, Jobs & Requests
    Last Post: 31-10-2012, 09:30 AM
  5. WANTED: Needed for my build
    By jpcnc in forum Items Wanted
    Last Post: 08-01-2011, 02:22 PM
