    Argyri,
    Looking good!
    The best place to get the Hiwin CAD models is http://www.hiwin.de/en/CAD_Configurator.html
    Most cost effective way to get the rails and carriages is to go east. I would suggest that you get carriages with preload so they do not have any slop, it adds a bit to the friction but worth the extra effort.
    In order to account for distortion etc I would suggest you build, level and then drill. A hand drill with good bits and a drilling jig like you describe is good as long as you make provision to straighten the rails afterwards. Have a look at installation instructions from HIWIN which is similar to this NSK one for ideas on mechanisms to align and adjust for straightness and squareness, if you haven't already done so.
    You could have the top sections on bolts but what would be the benefit if you epoxy level and drill afterwards? From our conversation it seemed that you were not thinking of moving the machine around so stripping it down is not needed. I would have thought that, should you crash the machine, you would need to readjust everything including the rails. In a rigid system, you will potentially only need to readjust the rails.
    Regards
    George
    https://emvioeng.com
    Yeah that seems reasonable.
    I see a few things I would change but rather than put into words it's easier to show you. Most Should be obvious but ask if not sure.
    The reason for top rail being longer at each is to recover some wasted bed space plus makes machine shorter. Also allows gantry to ride past the end so can use end of machine for standing boards upright or fitting 4th axis across end if required. Long overhang would be rear short would be front.
Name:	front frame.png
ID:	16880Click image for larger version.
ID:	16881Click image for larger version.
ID:	16882Click image for larger version.
ID:	16883Click image for larger version.
Name:	top frame.png
ID:	16884Click image for larger version.
    Dean,
    Thank you very much for your help I really appreciated.
    Smart way to increase the cutting area and add future use(4th axis)
    Few questions and I think I am good to go.
    Steel tubing for the whole base 60 x 60 x 5 ? Do you agree on that?
    Length of the bed 2600 + 100 short overhang + 300 long overhang = 3000 total would that be o.k? Do the overhangs need to be braced?
    What are the spacing of the cross members and the top rail supports in your drawings? No dimensions so I can't calculate.
    Has anyone joined hiwin rails lengthwise let's say 1500 + 1500 to achieve 3000mm length. Is it doable for the home builder? ordering from BST automation 3000mm rails will make shipping cost way up.
    Hopefully I will be start building in the beginning of January.
    Quote Originally Posted by arg123 View Post
    Well kind of but only has a minimum. I'd be more inclined to go with 80x80x5 on such large machine but 60x60 will work fine.
    Dimensions will depend on your needs and gantry etc. I only drew this frame to show you and save explaining via text.
    That said the dimensions I used where based on previous machines I've designed and are very close to those you mention.
    From memory the short overhang was 150mm and the large overhang is the same length has the gantry width. Bracing on large overhang depends on gantry width but if more than 300mm then yes brace it.
    Here's a 4x4 machine built using similair frame design but with adjustable height bed. Frame is 60x60x5 box.
    Yes it's commonly done on really long machines but does need careful fitting. Thou If possible I'd avoid doing it.
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 801. Received thanks 101 times, giving thanks to others 176 times.
    Just a note, if joining rails the lengths have to be a different size, Hiwin Installation Manual says you should not have joints directly opposite each other,( I might have to join rails as i have already purchased some but need longer length)
    Regards
    Mike
    Following Dean's drawings I finalized the base design, so any comments and corrections before I start cutting would be appreciated.
ID:	17125Click image for larger version.
ID:	17126Click image for larger version.
    Blue steel (top rails) is 80 x 80 x 5.
    Red steel is 60 x 60 x 5.
    Green steel is 60 x 60 x 3. (trying to save on weight).
    Top rails would be bolted to the supports for alignment purposes and use epoxy putty(later I would need some more details on that) and then epoxy leveling. Final length of the top rails (overhang) to be decided along the process.
    What height from ground to top rails is recommended?
    I ordered a straight edge 2000mm DIN 874/2 from same place Boyan did, thank you Boyan for posting the link,
    and I also have a precision level 0.02mm/m so I hope I will have a quite true reference plane to start.
    Thank you
  1. Build log. Design advice needed.
    By eurikain in forum Gantry/Router Machines & Building
    Last Post: 25-06-2015, 06:53 PM
  2. What's needed for a 3d printer build??
    By Davek0974 in forum 3D Printing Machines
    Last Post: 18-02-2014, 11:54 AM
  3. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  4. RFQ: Help needed to build my first machine NE Norfolk
    By Dorg in forum Projects, Jobs & Requests
    Last Post: 31-10-2012, 09:30 AM
  5. WANTED: Needed for my build
    By jpcnc in forum Items Wanted
    Last Post: 08-01-2011, 02:22 PM
