  1. #7
    eurikain I think Graeme is correct. But lets start with basics First disconnect the transformer and measure the resistance of the primary (blue and Brown) wires it should be quite low if you don't have a meter just use a battery and lamp to see if you get continuity. If that sis OK do the same for the secondary coils. It probably is OK.
    The next step is to connect the primary (brown and blue) to the 230V supply and then as Graeme states measure the voltage on the two secondary coils if you are getting 25V on each you are good to go.
    Try that and report back.
  2. The Following User Says Thank You to Clive S For This Useful Post:
  1. Toroidal Transformer
    By Carlb1058 in forum General Electronics
    Last Post: 17-08-2013, 06:54 AM
  2. FOR SALE: 2x55V Torroid Transformer
    By m_c in forum Items For Sale
    Last Post: 02-05-2013, 11:57 AM
  3. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
  4. FOR SALE: Transformer - large toroidial from amplifier
    By Jonathan in forum Items For Sale
    Last Post: 05-06-2011, 05:31 PM
  5. Solid State Relay to Switch Transformer?
    By m_c in forum General Electronics
    Last Post: 08-09-2008, 11:19 PM
