Thread: Toroid transformer no ouput
Yes it does have such a position :) Let me check :))
13-12-2015 #2
Touching the meter pins together creates beeeeeeep.
Primary:
no beep
Secondary:
red+black = beep
yellow+orange = beep
red+orange | red+yellow | black+yellow | black+orange = no beep
13-12-2015 #3..Clive
13-12-2015 #4
:'( Oh well.. I will call rapidonline tomorrow morning, see what we can do.
Where am I supposed to put that fuse you are talking about ? Can you show a wiring diagram ? How many amps does it need to be ?
13-12-2015 #5
Have a read throught this http://www.mycncuk.com/threads/9268-...se-Spindle-VFD. Message #46 gives a good diagram for all the electrics and shows where to put fuses or MCB's. One nice thing about the UK is we have fuses in our mains plugs, so if something goes wrong there is generally a fuse that will blow before any major damage is caused.
Because you are using a torroidal transformer, the inrush current (how much current is taken when you first apply mains power) can be many times the rated current of your transformer. You may have to use a bigger fuse than you think, but also be carefull to not go too far as you could cause damage if you do get a short.
Can I also make a suggestion to you. The wires from the transformer to the rectifier and to the capacitors should be much shorter and more heavy duty - at least the same wire size as the transformer wires.
13-12-2015 #6
Thank you very much for the link and for the suggestion. I will unsolder everything and switch to bigger wires. I was using typical 230V wires and did notice that they were a bit thin but they are the same size as the input 230V on the transformer. I'll do that again next week and post back here.
13-12-2015 #7
For info here was my power supply build. Bit late now (!) but you can see the colour coding on the transformer, plus I also noted higher gauge wires on the secondary which I matched. Remembering back to my school days when the transformer coil drops the voltage it increases the current, which means larger cables. So I think that on the primary you have high voltage and low current (small gauge) and on the secondary you have low voltage and high current (large gauge).
http://www.mycncuk.com/threads/6988-routercnc_MK3/page5
Post #43 onwardsLast edited by routercnc; 13-12-2015 at 08:12 PM.
Toroidal Transformer
By Carlb1058 in forum General ElectronicsReplies: 7Last Post: 17-08-2013, 06:54 AM -
FOR SALE: 2x55V Torroid Transformer
By m_c in forum Items For SaleReplies: 4Last Post: 02-05-2013, 11:57 AM -
Centre tap transformer?
By veedub1955 in forum General ElectronicsReplies: 5Last Post: 15-05-2012, 11:10 PM -
FOR SALE: Transformer - large toroidial from amplifier
By Jonathan in forum Items For SaleReplies: 1Last Post: 05-06-2011, 05:31 PM -
Solid State Relay to Switch Transformer?
By m_c in forum General ElectronicsReplies: 13Last Post: 08-09-2008, 11:19 PM
