    Are you typing G Zero or G small o as you have written it ?
    John S -
    G0 From the numbers row . ie 01234 Its what I do at work thanks
    keith re-install Mach and try again. It could be Mach's gone tits up.
    I had it do crazy thing on me other day in Mill mode. Was just like was stuck in Exact stop mode but it wasn't. Nothing I did made any difference and everything worked fine just machine was jerking it's head off.!! . . . Re-installed mach and away it went.
    Thanks Dean that's what I had mind plus reinstall plugin .will do at weekend and let you know
    Hello to all . Finally got it sorted ? The lathe was doing all kinds of crazy things , even the limit and e stop was dodgy. So I did a total reinstall off mach3 and smooth stepper drives. Still crazy .So I got the pc from the house and used that and its perfect. Does all the things it should . So got a used gaming pc ( fast processor and 8 meg memory) and that works fine too. Any one want a slightly dodgy ibm pc.
    Made some bike parts today. Everything works well with the machine . The speed is correct and stable and the turning wizards all work fine. Then I tried to use the screw cutting wizard . 1 mm pitch is about 5 it cuts left to right and the clearance cuts the bolt . Its all reversed ?. any body any ideas
  1. My CNC converted Harrison M250
    By M250cnc in forum Conversion Build Logs
    Last Post: 14-01-2022, 09:20 PM
  2. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  3. Harrison Trainer 280 CNC lathe
    By markems0 in forum Milling Machines, Builds & Conversions
    Last Post: 25-08-2010, 12:17 PM
  4. WANTED: 11" Harrison
    By Alfaman20 in forum Items Wanted
    Last Post: 28-06-2010, 11:46 PM
  5. Harrison M250
    By Arthur Kingdon in forum Milling Machines, Builds & Conversions
    Last Post: 14-06-2010, 08:36 PM
