Thread: Coolant Pump
Page 1 of 3 123 LastLast
    Chaz's Avatar
    So my Denford's little pump is struggling and I would like more pressure to 'wash away' the chips.
    Any thoughts on retrofitting something like this?
    https://www.keengardener.co.uk/hozel...giHRoCnb7w_wcB
    It seems to give good pressure, see vid.
    https://www.youtube.com/watch?v=WKUoul-f2io
    I would look at the 'submersible' ones but I dont want to cut the coolant tank if they do not fit into the hole of the current pump. With the pump above I can simply run the inlet into the tank.
    If you have any chips in the liquid, then your pump will go dead within short time.
    For this are the normal centrifugal pump centrifugal pumps much better, because they have no problem with parts up to 1cm, sometimes more.
    Chaz's Avatar
    Quote Originally Posted by uli12us View Post
    Understood however the pump comes with a filter which should mitigate that issue.
    Chaz's Avatar
    I also have dual 'grates' which catch the material and stops it from entering the coolant. Not perfect but the amount of crap that should be in the coolant is minimal.
    I recently purchased and fitted one of the 1/8 ph coolant pumps off ebay to my triac, very pleased with it and the power.
    Chaz's Avatar
    Quote Originally Posted by andy_con View Post
    Link please? How does it compared to the standard Triac pump?
    Chaz's Avatar
    These?
    http://www.ebay.co.uk/sch/i.html?_fr...+pump&_sacat=0
    I found them on Rotagrip's site .... they have lots of nice stuff.
    Those are the ones, I can do you a vid over the weekend if you want.
    Can't remember what size but they do one thats a perfect fit length wise.
    As for power it's plenty of power for me, removes chips out the way nicely
  9. The Following User Says Thank You to andy_con For This Useful Post:
  10. #9
    Chaz's Avatar
    Thanks. A vid will be very much appreciated. Where abouts are you based?
  11. #10
    Essex .
  1. Coolant, I am not sure which one to go with.
    By suesi34e in forum Swarf & Chip Management
    Last Post: 17-10-2015, 07:13 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  3. Washing Machine Pump Coolant System
    By Lee Roberts in forum Electronic Project Building
    Last Post: 05-05-2012, 01:30 AM
  4. coolant
    By luke11cnc in forum Machine Discussion
    Last Post: 11-02-2012, 01:17 PM
  5. What coolant to use??
    By don_jarr in forum General Discussion
    Last Post: 05-11-2011, 03:12 PM
