Thread: Coolant Pump
    Chaz's Avatar
    Quote Originally Posted by andy_con View Post
    Those are the ones, I can do you a vid over the weekend if you want.
    Can't remember what size but they do one thats a perfect fit length wise.
    As for power it's plenty of power for me, removes chips out the way nicely
    Hi mate, any joy with that vid?
    best I could do sorry, didn't do any machining this weekend
    Chaz's Avatar
    Thanks. Very helpful. You motor is on top whilst mine is in the cavity lower down (the full coolant system) so mine will have to pump a bit higher but not a lot more.
    I could try and fix the motor setup I have, could machine a new based for it but probably not worth the effort. Id probably go for the 1/4 HP motor if I can get it to fit without cutting the sheetmetal.
    Thanks once again.
    I am thinking about replacing the pump on my triac also, I have the large coolant tray like yours Chaz.
    I found these coolant pumps made by excel machine tools. You can buy them from brammer.co.uk. The 1/8hp one is £82 and the 1/4hp is £145.
    Chaz's Avatar
    Quote Originally Posted by jamesgates1000 View Post
    Out of interest, have you measured the physical size of our pump to know what size will be a like for like replacement without needing to make holes or cut the motor mount wider?
    I haven't but I will put all the dimensions on here when I get my tray back. It had obviously been left with coolant in it for some time before I bought it, all the water had evaporated off and the oil stripped the paint from the bottom of the tank. It is at the local bodyshop being stripped and powder coated.
    Chaz's Avatar
    Ah OK. Not a biggie, will take me a few mins to measure.
  1. Coolant, I am not sure which one to go with.
    By suesi34e in forum Swarf & Chip Management
    Last Post: 17-10-2015, 07:13 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  3. Washing Machine Pump Coolant System
    By Lee Roberts in forum Electronic Project Building
    Last Post: 05-05-2012, 01:30 AM
  4. coolant
    By luke11cnc in forum Machine Discussion
    Last Post: 11-02-2012, 01:17 PM
  5. What coolant to use??
    By don_jarr in forum General Discussion
    Last Post: 05-11-2011, 03:12 PM
