  1. #16
    Rob I see the trouble with this is starting the machine code with the switch not in the correct position and then not getting to the Osh#t button fast enough
    I agree, but when you have done it a couple of times, you learn. I check the switch is in the correct position, but the 'always on' position is down, so you can hit it faster than the osht in my case. After having my finger bitten by the machine, it also helps my confidence to put it to 'off' whilst doing a tool change and restarting the code does not fire up the spindle, so I switch it to 'on' before continuing. My new Cam software puts out the M03 after a tool change though.
  2. The Following User Says Thank You to cropwell For This Useful Post:
  1. Which wiring diagram software do you use ?
    By eurikain in forum Computer Software
    Last Post: 11-10-2015, 02:48 PM
  2. VFD Wiring Diagram
    By Tomnewry in forum General Electronics
    Last Post: 14-10-2013, 06:46 PM
  3. Wiring diagram for 4x4 cnc router
    By Danielroyal25 in forum General Electronics
    Last Post: 19-07-2013, 11:14 PM
  4. NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
    By Sampop in forum New Member Introductions
    Last Post: 28-10-2010, 11:18 AM
  5. Hardinge hc chucker wiring diagram
    By hrdg4me in forum General Electronics
    Last Post: 16-12-2009, 03:57 PM
