Thread: Wiring Diagram check
20-12-2015 #20
My connector CN1 is just there to show the connection point to the BoB.
Do not try and power anything from the BoB input terminals. They may be at 5v due to internal pull-up resistors, but they will not supply enough current and you may damage the BoB. Likewise the output terminal should not feed any circuit with any power demand greater than a relay.
The buzzer can be any small DC buzzer, just feed the +ve side from an appropriate power supply, 5 or 12v depending on your buzzer. I just happened to have a couple in a drawer.
As Clive said my warning buzzer is a separate side of the switch. On my machine I separate ++ limits from -- limits so I use a 3pole double throw switch to override both inputs and also earth the buzzer.
Don't try and Home the machine when a limit is being overridden. You may be the wrong side of the Home switch and your machine will try to keep going in the wrong direction.
Before you connect Home and Limits to the BoB, verify they are correctly wired using a test meter. BoBs are fragile little buggers, so treat them well.
Why are you using a relay for Limits switching ? It only adds more to go wrong ! What would happen if your 24v power failed and you didn't notice.
Cheers,
RobLast edited by cropwell; 20-12-2015 at 02:01 PM. Reason: Additional Info
Which wiring diagram software do you use ?
By eurikain in forum Computer SoftwareReplies: 3Last Post: 11-10-2015, 02:48 PM -
VFD Wiring Diagram
By Tomnewry in forum General ElectronicsReplies: 9Last Post: 14-10-2013, 06:46 PM -
Wiring diagram for 4x4 cnc router
By Danielroyal25 in forum General ElectronicsReplies: 1Last Post: 19-07-2013, 11:14 PM -
NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
By Sampop in forum New Member IntroductionsReplies: 1Last Post: 28-10-2010, 11:18 AM -
Hardinge hc chucker wiring diagram
By hrdg4me in forum General ElectronicsReplies: 4Last Post: 16-12-2009, 03:57 PM
