    Quote Originally Posted by eurikain View Post
    I was also wondering what the 10-24V inputs of the BOB (between top 2 and bottom 2 pins you connected to the VFD) are used for ?
    It's so you can power using an external source rather than USB and I suggest you do that. USB is unreliable and not to be trusted.
    I have it powered by the USB port but it's connected to a 5A 5VDC PSU, don't worry :D
    Also Jazz may I ask out of curiosity what tool you used to draw the connections ? :)
    USB can't be trusted, but it isn't as bad as USA.
    On a serious note, USB ports on a computer have a very low current sourcing capability.
    Go to bed Rob, you're tired :D
    True, but you can still use the port if you power it with an external PSU :)
    I think with that board, if you put an ohmeter on the +5v pin of the USB socket, it shows it connects to the +5v screw terminal connector, so the USB way of supplying power to the board is provided for those who want the quick and dirty solution.
    Cheers,
    Rob
  1. Which wiring diagram software do you use ?
    By eurikain in forum Computer Software
    Last Post: 11-10-2015, 02:48 PM
  2. VFD Wiring Diagram
    By Tomnewry in forum General Electronics
    Last Post: 14-10-2013, 06:46 PM
  3. Wiring diagram for 4x4 cnc router
    By Danielroyal25 in forum General Electronics
    Last Post: 19-07-2013, 11:14 PM
  4. NEW MEMBER: Hi, Looking for a wiring diagram, Melbourne
    By Sampop in forum New Member Introductions
    Last Post: 28-10-2010, 11:18 AM
  5. Hardinge hc chucker wiring diagram
    By hrdg4me in forum General Electronics
    Last Post: 16-12-2009, 03:57 PM
