    Hi all, I have a question, my extractor unit is in a not easily accessible place so the no-volt switch is awkward to get to and I don't want to move all the pipework.
    What i would like to do is to move the switch by my bench, not a problem, what I would really like to do is have two no-volt switches one on each bench
    Now can you have 2 no-volt switches on one machine? how would you wire it up? any foreseen problems?
    Looking forward to your answers
    John
    This circuit is drawn for 6v but 240VAC is the same principle. It uses two normally open switches to turn on power and complete the loop that holds the relay on. and two normally closed switches as a hold loop which when you press one, lets the relay drop out. In my workshop, to switch single phase power, I use a 100A contactor with two poles used to switch live and neutral and the other to make the loop. It means I can put emergency switches round the place, but I only have one switch on point, near the door. It also means that I can switch off everything in one go, when I leave. It also acts as an NVR switch if there is a power failure.
    NVR switches generally have a simpler design, where the ON button pushes the contacts and the Off button breaks contact or pushes the contacts apart, like the manual operation on a contactor.
    Hope this helps.
    Rob
    have you ever thought about a wireless switch ?
    Quote Originally Posted by gorbo View Post
    John
    I use wireless switches for my lighting and one for the shop vacuum, for the vac the key-fob transmitter is on the end of the hose so wherever I have the hose running to in the workshop, there's the switch ;-)
    - Nick
    do you have a link to the system you used please
    Thanks for the replys,
    Went a different way in the end, put in a ceiling switch (ex shower ) in a central position works really well, merry Christmas all
  1. DC motor control
    By phill05 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 24-12-2014, 04:10 PM
  2. servo control vs stepper control
    By Peter. in forum Motor Drivers & Controllers
    Last Post: 17-09-2012, 08:36 AM
  3. Help with spindle control
    By wizzy in forum Spindles & Drive Motors
    Last Post: 12-02-2011, 12:51 AM
  4. PC case control box
    By lateAtNight in forum Electronic Project Building
    Last Post: 02-02-2010, 03:27 PM
  5. motor control
    By Phil Gravett in forum Motor Drivers & Controllers
    Last Post: 09-06-2009, 05:02 PM
