Quote Originally Posted by Rufe0 View Post
The distance traveled per revolution with rack and pinion is the pitch circle of your pinion gear diameter * pi, for example 1inch 25.4mm pitch circle diameter pinion gear, 25.4*3.145 = 79.883mm distance traveled per revolution. Divide that by your stepper motor step count which is normally 200. 79.883/200=0.399415. So the resolution is 0.399415... so to get that 0.001 resolution I was talking about you'd need a 300:1 gear ratio, which is crazy. 0.001 might be a little optimistic... but the point being that the problem of smooth slow feeds will be much worse with rack and pinion.
Don't get me wrong rack and pinon is great for soft material routers that need high speeds but I don't think it's correct for your application. Of course you could probably make it work but it wouldn't be the ideal solution.
ok then i will stick to the screw system but i am worried about the length 3 m , and i think there is a problem in my setting of the driver i am using ,this is the setting i am using on the driver
Name:	Screenshot 2016-01-12 14.33.51.png
