I have a bantam 2000, and while very similar to the harrison 250/300, there are subtle differences. For example, I favour the colchester because the cross slide is operated by my left hand, saddle is operated by my right (I came from a boxford), on the harrison you would operate the cross slide with your right hand, and the saddle with your left (same as a myford) for me it`s a bit like having to re - learn how to use a lathe when I use my friends harrison, I always end up crashing into the workpiece because of the way the handles are set. I have also had a myford, and by comparison, I would much prefer the colchester as it`s about 3 times larger.
25-12-2015 #2
25-12-2015 #3
I would certainly choose the colchester over the myford, simply because of it`s increased capabilities. One thing that I maybe should mention is that my colchester is 3 ph, and has a dual speed motor. This meant that I had to go for one of the bigger phase convertors, (transwave), as opposed to one of the small VFD`s (well, thats what my electrician advised).
This added a fair bit on to the total cost of the setup, whereas my friend uses a harrison which simply runs off a small VFD, and ultimately gives him full speed control.
Unfortunately, I can`t comment on the warco, as I have never used one ! or even seen one in the flesh. I also think that a good used harrison will always hold it`s money, so that may be something to consider if you plan on changing in the future. Sorry I can`t be of more help.
25-12-2015 #4
Looking carefully at the lathes.co.uk article, I think the Bantam that we are discussing is a Mk2 2000, which is definitely not the same as the Harrison 250 clone later Bantam 2000 (Mk3 Bantam). Position of saddle handwheel and leadscrew lever notwithstanding (and I understand the issue having a Smart and Brown and a Myford in the workshop with opposite handed controls) my personal choice, if the Bantam is in reasonable condition, would be to go for the Bantam. Again, based purely on personal experience and my own needs, I find that the bigger, heavier, machine just seems so much nicer to use, and the extra capacity is there if needed. Mind you, that is comparing the S&B to the Myford; the S&B has a similar capacity to the Bantam but weighs around 3 times as much, so not quite the same animal. I used to use a Bantam many years ago in the student workshop at University and I remember it as a good machine to use. However, I would still wonder about hanging on a little longer just to see if a better-equipped machine turns up (or even have a look at some of the dealers' websites to see what is on offer there - G&M, Home and Workshop Machinery, etc). The eBay machine seems a bit short on the tooling and chucks and there is that question mark over the replacement topslide feedscrew (if that's what it is).
26-12-2015 #5
The difference in the scales isn't really important. If you have a 1/10" or 2,5mm spindle, then the difference is only 0,04mm per revolution.
If you make a raw work with the machine, then a mm more or less makes nothing. After that you take away 2-5/10 so you need only 1/5 of the spindle, so the maximum error is in the range of 0,008mm.
The backlash of a spindle is more important.Last edited by uli12us; 26-12-2015 at 02:44 PM.
26-12-2015 #6
Thanks. Still a bit confused. Are we saying the 2nd 'old' lathe is better than the first (original ebay advert) and it seems the Warco is generally not the first choice?
I bought a 4KW VFD to power a few different things. It *should* power most of these lathes but I dont have their exact specs to know for sure.
26-12-2015 #7
Also an option?
http://www.ebay.co.uk/itm/colchester...3D231773982948
Not sure how Id collect it however...
26-12-2015 #8
It's your money, Chaz, so it's very easy for us lot to give advice! However, that link in your last post looks to me a better option than the original one, mainly because it's better equipped. Transport could be an issue, of course, but that's going to be the case for most of these unless they come from a dealer with their own transport. I had my (2800lb) lathe fork-lifted on to a hired flat-bed Transit and arranged for a friend with tractor and front-loader to take it off for me.
Again, because it's all got a bit rambling and confused, my own preference would be for a decent second-hand machine rather than a new Warco. Purely my personal choice, and I'm happy that I went that way, even though my machine still needs a bit of work to get it working absolutely 100%.
A 4KW VFD should be enough to drive any of these machines, as long as you can rewire the motors as 240V rather than 415V (probably wired as 415V as standard). I'm assuming that your VFD is 240V 3-phase; chances are that none of these lathes are going to have bigger than a 3HP or so motor which translates to 2.2KW, well within capacity.
Laser for under £2000?
By KevinC in forum Laser Machines & BuildingReplies: 4Last Post: 22-11-2015, 10:57 PM -
Sherline 2000 CNC Mill
By cooliced in forum Sherline MillsReplies: 37Last Post: 12-01-2013, 10:22 PM -
NEW MEMBER: Hello from Staff 2000
By Alex@staff2000 in forum New Member IntroductionsReplies: 1Last Post: 21-11-2009, 12:23 AM -
Mach 2 / 3 - Windows 2000/XP
By teetat in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 10-07-2009, 02:47 PM -
Best cnc mill for under £1500-£2000
By xchipx in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 05-03-2009, 08:42 PM
