Hi all,
I haven't got round to testing the enable pins on the drives yet as I need to order the correct connectors (http://uk.rs-online.com/web/p/non-fu...locks/1896010/ in case it's useful to others).
I have tested the enable pin on th BoB and got a slightly odd result:-
1. BoB off, PC on - 2.26v
2. BoB off, PC on, Mach 3 loaded - 1.09v
3. Mach3 loaded, BoB on, emergency stop active - 4.97v
4. Mach3 loaded, BoB on, ES reset - 195mv
5. Mach3 not running, BoB on - 4.9v
6. PC off, BoB on - 4.9v
So they all look ok to me except for number 2. From what I understand TTL levels a Low is 0v to 0.8v and a High level is 2v to 5v so a voltage of 1.09v is neither low of high which may or may not cause problems.
Anyone expirence this kind of thing before?
Thanks,
Jim
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
BOB & Stepper Drive
By GTJim in forum General ElectronicsReplies: 9Last Post: 22-08-2013, 07:17 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
Stepper Motor Wire Colour Codes
By c cunningham in forum Stepper & Servo MotorsReplies: 14Last Post: 26-01-2011, 02:13 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
