Thread: Keeping micro step position
28-12-2015 #1
I have analogue drives (DQ860MA) and when switching on there is a thud from the steppers depending on how far they are away from a whole step and the ballscrew rotate slightly. Normally this is fine as I home the machine etc. but on a recent job I was surfacing a part and had to stop part way through. I wanted to keep the Z height exactly where I left off so I attached a DTI to the Z axis switched on (which moved the needle slightly) and then I jogged it back to zero.
Out of interest is there any way of knowing before switching off how far the stepper is from a whole step? I know some drivers have the feature of remembering which micro step they are in but is there any other way of knowing using the drivers I have now?
Keeping hywin rails clean?
By charlieuk in forum General DiscussionReplies: 11Last Post: 01-01-2015, 03:12 PM -
keeping DTIs perpendicular for runouot checks
By dsc in forum Machine DiscussionReplies: 9Last Post: 13-03-2014, 02:41 PM -
Question on Micro step resolution?
By Ross77 in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 12-02-2013, 04:08 AM -
BUILD LOG: Widgetmast micro mill
By HS93 in forum DIY Router Build LogsReplies: 0Last Post: 06-07-2010, 12:37 AM
