    If you buy it in the UK, around £200 per litre. Its pricy stuff.
    I paid less via a friend in Germany.
    Oh wow. 200 per kilo?
    I paid 75€ for 3 kg.
    Not West though.
    Chaz's Avatar
    Quote Originally Posted by driftspin View Post
    Not West though.
    What do you mean with 'No West though'?
    I was unable to get 105 icw 209 so i looked for a alternative epoxy.
    With similar end strength properties an slow hardning like west 105 / 209.
    Chaz's Avatar
    Ok, however different application here.
    Episode 16 is now ready. Having another go at the epoxy leveling . . .
  6. The Following 4 Users Say Thank You to routercnc For This Useful Post:
  7. #6
    Much more better,Looks promising.
    Mike
  8. #7
    Mike
    Thanks Mike. Yes much better this time thanks to help on this forum. Something to note - I edited it out because it didn’t work but I had an electric sander in the vice (no paper) inverted which I rested the Epoxymatic container on but it just fizzed the water bath and the epoxy did nothing. I think the sander was too strong and the epoxy was isolated by the rubber washer. Mixing slowly, draining from the bottom (I mixed a bit more than I needed), and using a stick to pop the bubbles all helped.
    Getting up close there is still the occasional small bubble but it is much better than before.
    Need to leave it a week or two and not be tempted . . .
  9. #8
    Good job, I bookmarked this vid for when I have a go.
  10. The Following User Says Thank You to Desertboy For This Useful Post:
  11. #9
    Episode 17 - time to find out if the epoxy worked and how flat it is . . .
  12. The Following 3 Users Say Thank You to routercnc For This Useful Post:
