Page 26 of 36 FirstFirst ... 162425262728 ... LastLast
  1. #251
    What do you mean with 'No West though'?
    I was unable to get 105 icw 209 so i looked for a alternative epoxy.
    With similar end strength properties an slow hardning like west 105 / 209.
  2. #252
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 2 Days Ago Has a total post count of 1,653. Received thanks 115 times, giving thanks to others 71 times.
    Quote Originally Posted by driftspin View Post
    Ok, however different application here.
  3. #253
    Episode 16 is now ready. Having another go at the epoxy leveling . . .
  4. The Following 4 Users Say Thank You to routercnc For This Useful Post:
  5. #254
    Much more better,Looks promising.
    Mike
  6. #255
    Mike
    Thanks Mike. Yes much better this time thanks to help on this forum. Something to note - I edited it out because it didn’t work but I had an electric sander in the vice (no paper) inverted which I rested the Epoxymatic container on but it just fizzed the water bath and the epoxy did nothing. I think the sander was too strong and the epoxy was isolated by the rubber washer. Mixing slowly, draining from the bottom (I mixed a bit more than I needed), and using a stick to pop the bubbles all helped.
    Getting up close there is still the occasional small bubble but it is much better than before.
    Need to leave it a week or two and not be tempted . . .
  7. #256
    Very nice and what patience, I have done a similar thing with a plastic jug with a hole in the side with tape over it then removed the tape for the pour. Nice work with the broken tap as well
  8. #257
    Cheers Clive. Yes I thought about your tape method but in the end I wanted to also have a warm water bath around it to help with the bubble removal so went with the water butt tap. As it turned out I only put a bit of hot water in and then chickened out as it felt like the plastic was relaxing and I had visions of the rubber washer failing letting the water into the epoxy. In the end it was pretty hot in the workshop ( heaters on again) and it flowed ok. Not sure I would go with the water bath again . . .
    On the other tap I could have ordered a carbide drill but I had it fixed within the hour and it was on with the build !
  9. #258
    Meticulous as always! Looks more promising this time.
    Broken taps... what a pain!
  10. #259
    Cheers Zeeflyboy !
    Looks much better this time. Couldn't resist a quick look tonight (I only poured it yesterday) and it looks so much better than before . . .
    I used a ground flat edge and there was no rocking.
    Then I noticed something at the far end !!!
    Checked it with the flat edge and it is very slightly raised:
    This is where I popped and removed the last bubbles with the stick so it looks like it was starting to set. I'm confident I can lap this back down when dry.
    Onwards . . . !
  11. #260
    Good job, I bookmarked this vid for when I have a go.
  12. The Following User Says Thank You to Desertboy For This Useful Post:
