Thread: Here we go again . . . MK4
20-02-2018 #221
Yes but it might have been clicked by mistake, easy to do
20-02-2018 #222
The Following User Says Thank You to Davek0974 For This Useful Post:
20-02-2018 #223
I didn't want to say anything as you are doing a cracking job on your build, however if i had to bore a pulley i would have set it up in a 4 Jaw with 4 short pieces of silver steel inserted into the belt slots and clocked on the OD of the pins then it's spot on with the newly bored hole. however if you don't have a 4 Jaw this isn't an option.
Mike
20-02-2018 #224
Hi Mike
I welcome suggestions on other ways to do things so please do mention them. I've only had the lathe a year or so and still lots to learn. I do have a 4 jaw chuck and it takes a bit of time to swap over (retaining nuts are a bit fiddly to access) but I like your idea. Pity I've just bored out the ones for the X axis so they are all done! Next time though . . .
16-03-2018 #225
Episode 13 is now ready - machining the ball screws and installing them on the bed.
(Contains some paid for content)
The Following 2 Users Say Thank You to routercnc For This Useful Post:
16-03-2018 #226
I spotted the "this old tony" bit with the 4 jaw
nice as always.
16-03-2018 #227
16-03-2018 #228
Does the grubscrew for your pulley locate on the actual ballscrew ?
Looked like it might be fixing into your extension.
Regards
Mike.
Thanks for the update
16-03-2018 #229
07-04-2018 #230
OK, episode 14 is now ready. This time we finished off the Z axis ball screws and wire up the new steppers.
