Thread: Here we go again . . . MK4
08-11-2018 #291
Thank you! That's helpful, I will certainly give your suggestion a try.
On a different note, have you had any challenges with the ball screw lock nut in the past? I noticed on my router that the lock nuts will back out when the gantry is moving in one direction, I know that the lock nut is supposed to preload the inner race of the AC bearings, and the set screw on them are so tiny and I can't really torque them hard or they will strip, to be honest the set screws don't seem to work that well. I've seen people order ball screws with a longer thread for two lock nuts back to back, but it's not an option for me any more. Any suggestions or solutions would be appreciated.
Thank you!
08-11-2018 #292
I have had them come loose occasionally over the years. I've always managed to tighten the nut and carefully tighten the grub screw but yes there is the fear of stripping the thread or more likely rounding out the allen key hole.
Other options to think about:
As you say, longer screws and double lock or jam nuts
Maybe blue loctite on the nut but don't get it near the bearing, or maybe PTFE tape??
Dropping a short length / disc of brass rod in the grub screw hole first, then the grub screw will mold it onto the thread
Making a brand new nut from steel (and then heat treating it) with a larger grub screw?
Anything from anyone else?
The other thing to think about is how to hold the ball screw when tightening the nut (once it is all installed with coupler on etc.). I fold up plenty of shop towels into a narrow strip about 30 mm wide then wrap it around the ball screw. Then apply as much pressure as you dare using a mole grips . . . . . pause while I find the US name for such as tool . . . . vice grips, to hold the ballscrew and tighten the nut using a spanner/wrench.
08-11-2018 #293
11-11-2018 #294
I use oneway bearing wrench to hold the ballscrew when tightening the nuts.
Also, my SYK bearing holders have nuts with setsrews, but the thread hole does not go all the way tru so you don't destroy the ballscrew threads.
This is my wrench:
https://www.amainhobbies.com/align-f...t00005/p213519
12-11-2018 #295
13-11-2018 #296
14-11-2018 #297
Yes, for a plain shaft that is OK but remember this is pressing down onto the thread. A steel ball would damage the thread making it difficult to remove the nut so the brass disc is a better option as it is soft and will mold into place.
14-11-2018 #298
SYK nuts have brass inserts:
https://www.syk.tw/en/product/201705040003
You can buy them from resellers like cnc4you:
https://www.cnc4you.co.uk/BK12-12mm-Nut?search=Nut
The Following User Says Thank You to jkkmobile For This Useful Post:
29-11-2018 #299
30-11-2018 #300
