    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 22 Hours Ago Has a total post count of 807. Received thanks 101 times, giving thanks to others 176 times.
    I didn't want to say anything as you are doing a cracking job on your build, however if i had to bore a pulley i would have set it up in a 4 Jaw with 4 short pieces of silver steel inserted into the belt slots and clocked on the OD of the pins then it's spot on with the newly bored hole. however if you don't have a 4 Jaw this isn't an option.
    Mike
    Mike
    Hi Mike
    I welcome suggestions on other ways to do things so please do mention them. I've only had the lathe a year or so and still lots to learn. I do have a 4 jaw chuck and it takes a bit of time to swap over (retaining nuts are a bit fiddly to access) but I like your idea. Pity I've just bored out the ones for the X axis so they are all done! Next time though . . .
    Episode 13 is now ready - machining the ball screws and installing them on the bed.
    (Contains some paid for content)
  4. The Following 2 Users Say Thank You to routercnc For This Useful Post:
  5. #4
    I spotted the "this old tony" bit with the 4 jaw nice as always.
  6. #5
    Yes I have to pay homage to ToT.
    Would be nice if it really was that quick!
  7. #6
    mekanik's Avatar
    Does the grubscrew for your pulley locate on the actual ballscrew ?
    Looked like it might be fixing into your extension.
    Regards
    Mike.
    Thanks for the update
  8. #7
    Regards
    Mike.
    Hi Mike
    The grub screws in the hub go direct to the ball screw shaft. The green loctite holding the extension is good stuff but I wouldn't want to rely on it to transmit the drive.
    Note to others - if you want to use pulleys ask for longer sections!
  9. #8
    OK, episode 14 is now ready. This time we finished off the Z axis ball screws and wire up the new steppers.
  10. The Following User Says Thank You to routercnc For This Useful Post:
  11. #9
    Amazing build, has to be the heaviest Z axis I've seen yet.
  12. The Following User Says Thank You to Davek0974 For This Useful Post:
