Thread: Here we go again . . . MK4
02-08-2017 #131
This cnc build porn must stop!
(Please keep it coming).
05-08-2017 #132OK, as requested here is a video of making a fixture, setting up, and then line boring the spindle housing . . .Look forward to seeing the lathe work, will you be video'iiinngg it as you machine it?
Still lots to do but another step closer.
The Following 2 Users Say Thank You to routercnc For This Useful Post:
14-08-2017 #133
I've decided to do another video, which takes much longer to put together so let me know if this is better than posting pictures.
In this video I attempt to align the 4 rails flat and parallel to each other. They still need lateral spacing/alignment but that will be the next step when it is assembled into the Y axis and they are trammed in. Here are the edited highlights:
14-08-2017 #134
Patience of a saint very nice vid
14-08-2017 #135http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
14-08-2017 #136
great work, with the level of attention you are paying to the details this is going to be a very impressive machine at the end!
15-08-2017 #137
Cheers for the encouragement Clive, Desertboy, Zeeflyboy.
Next up will be re-machining another 1 mm off the Y axis pockets to correct the small CAD error I mentioned earlier, then assembly/alignment of the Z and Y axis. Hopefully no more surprises!
15-08-2017 #138
there are always more surprises!
26-08-2017 #139
More progress on the Z axis.
Finishing touches, lateral rail alignment, and fitting the ballscrew.
26-08-2017 #140
Beautiful, very nice big credit
