Thread: Here we go again . . . MK4
04-09-2017 #10
Hi Clive,
Thanks for the kind words. I made the grease nipple extenders from a bit of brass. See post #109 in this thread. The top blocks have the right angle in, and there are 4 off. The bottom one is straight and there is only one - it is used for each of the lower bearing blocks in turn and then the block is capped off with a small bolt. You can buy straight ones, but couldn't find an angled one the right size.
The valves are M6x0.75 fine thread, very cheap off ebay. Watch out, some M6 grease nipples are M6x1.0 (ballscrew nuts I think are this size.)
My angled ones needed to be indexed so that the horizontal part would be in the right place when the vertical part was tight. Lots of ways to do it but I tightened the vertical part and then marked the radial exit location.
Sorry got distracted part way through typing the reply, Paulus beat me to it.Last edited by routercnc; 04-09-2017 at 04:08 PM.
