    ok i attached the motors to the cnc and still no change. i aslo have change the ms to 1/4 and 80. still nothing.
    where can i find the step low active setting.
    Quote Originally Posted by Davo242 View Post
    Here.
    ok i will try that. just wondering one thing i only have the demo mode on at the min would that be a cause of anything?
    Only if your trying to run g-code more than 500 lines of code and it wouldn't cause stalled motors it would just stop moving.
    As a matter of interest what Voltage is your power supply to the drives?
    Chaz's Avatar
    I was just about to ask the same. Is the Voltage at the right level and 'clean'?
    That said, it does feel like a Mach 3 config issue, look at the end of the vid, the DRO numbers look to pause and then unpause ...
    its getting 24.4v
    Chaz's Avatar
    its getting 24.4v
    Is that what the drives need? Sounds low to me but could be correct, not looked at any specs etc
    what should the normal voltage be ? is there any way i could send u the maual for the drivers?
    Chaz's Avatar
    There isnt 'normal'. I tend to see 50-80V usually. What does teh specification of the drivers say?
  1. stepper motors
    By reefy86 in forum Gantry/Router Machines & Building
    Last Post: 06-09-2015, 12:54 PM
  2. Replies: 6
    Last Post: 27-05-2012, 06:06 AM
  3. Help with Stepper Motors
    By Scott in forum Stepper & Servo Motors
    Last Post: 04-04-2010, 02:35 PM
  4. rs stepper motors
    By chaz@2b in forum Stepper & Servo Motors
    Last Post: 06-08-2009, 11:05 PM
