It seems, you need an analogue control Unit like the CSMIO IP/A or you can change the servodrives to new parts which can controlled via Step/dir.
The last possibility will be cheaper, because you need only a bob, if you have not many IOs. But with many IOs its better you buy a dedicated
motion card, which can handle it.
The Following User Says Thank You to uli12us For This Useful Post:
02-01-2016 #2
i saw the CSMIO and was not sure which model. I assume you suggest that model as my older servos will be ananloge.
RE I/O there are limit switches, sensing air pressure for the spindle, power for the cooler. At present the spindle is connected to an extra axis, i assume to receive an analogue signal for the inverter driving the spindle. Can the CSMIO accept encoder input?
Mike
02-01-2016 #3
That depends what you want to do.
If you want to reuse the existing drives, you need the IP/A, if you want to change it for modern drives you can buy the IP/M. I don't know the prices,
but you need 100quid for one drive.
The new drives can be controlled with step/dir. But you must connect the encoder lines directly to the drives. They need to have an differrential (maybe single-ended is enough) TTL output. If you have another signal, then maybe you can change it, with special electronics. Or you must change it with an encoder from HP/avago.
Your drives are capable of a bit more then 60V and 3Amps continuous/ 6 Amps Peak for 1 second. So you need a brushed DC/Motor drive with not less then these amounts.
The only drives I found for my machine are Leadshine DCS810 or american Geckos, which are doubled as expensive.Last edited by uli12us; 02-01-2016 at 04:57 PM.
03-01-2016 #4
03-01-2016 #5
It will be cheaper to change the controller to the IP-A version, changing the motors and drivers will cost more than the new controller and will also need mechanical changes to the motor mounting flanges. After this you would then need to add a motion controller, because a standard breakout board will not handle the 24V I/O let alone the amount of I/O you will need.
This conversion will take time and this will cost more than the parts if you are paying someone else to retrofit it. Do you have the documentation on the machine? like the wiring or at least the installation manual for the controller and drivers?
before you go any further, you need to know if the existing motors and drivers are actually working? and you need to check if the encoders are incremental or absolute. If they are dodgy or absolute encoders, then changing the motors and drivers may be the way forward, but also changing the controller to an IP-S or M, but i would favour the S version.
I could do it, but i have about four other machines that i need to do first.
03-01-2016 #6
You don't need to change the motors, changing the drivers is enough.
60V and 3/6Amps isn't really expensive.
The Gecko 320X or leadshine DCS810 each with 80V 20Apeak are more than capable for this.
But the encoder of the motors must have a TTL output, single ended is enough.
03-01-2016 #7
03-01-2016 #8
These are the encoders being used:-
http://www.mct-ltd.co.uk/pdfs/counters/755.pdf
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
Spindle on/off under CNC software control - safety worries!
By HankMcSpank in forum Machine Control SoftwareReplies: 13Last Post: 12-02-2013, 03:47 AM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
What metalwork lathe should I get to replace Sieg C3
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 28-02-2011, 01:41 AM
