03-01-2016 #11
These Encoders are Incremental and Differential but it would be no big deal to use a line driver to convert single ended to Differential if needed.
The Encoders would have to go to the Drives in any case because the IP-S or IP-M don't have encoder inputs. Only the IP-A takes Encoder feedback.
Chaz the Tacho's are not used if using Step & Dir drives as they run in position mode and only needed for Analog drives for velocity feedback when used in Velocity mode.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Leadshine 4-axis motor motion control cards? Any experience and info?
By Boyan Silyavski in forum Motor Drivers & ControllersReplies: 0Last Post: 02-12-2013, 06:43 PM -
Spindle on/off under CNC software control - safety worries!
By HankMcSpank in forum Machine Control SoftwareReplies: 13Last Post: 12-02-2013, 03:47 AM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
What metalwork lathe should I get to replace Sieg C3
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 28-02-2011, 01:41 AM
