Thread: Mach 3 ports and pins problems,
11-01-2016 #17
Do you mean you want to Halt XYZ from Homing until A axis finished Homing.?
If so then this is very easy all you need to do is change the Homing script. By default Mach starts with Z then Y then X then A.
To change then goto Operator menu and choose Edit Button Script. On the Screen the Ref All Home button will flash. Click on it and it will open the script editor.
Now move the line that says "DoButton( 25 )" to the top of the list. The sequence will then be A, Z, Y, X. The other axis won't move until the A axis finish.Last edited by JAZZCNC; 11-01-2016 at 02:24 PM.
Parallel ports problems
By Cnc many in forum Computer HardwareReplies: 28Last Post: 16-12-2015, 01:59 AM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
problems with mach or windows
By johngoodrich in forum Computer SoftwareReplies: 2Last Post: 02-03-2012, 07:23 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
