Thread: Mach 3 ports and pins problems,
Are the channels repairable does anyone know?
chris w
10-01-2016 #2
The homing switches are fitted and working on the x,y and z there is also a switch fitted on the a axis and as the a only clamps every 45 degs the switch "sees" when the a is clamped but the OEM had not connected the switch to anything so I want to use it to confirm the a axis has finished moving and the the z,x and y axes can continue with movements,
i can't figure out how to disable any movements in xyz until this switch is made, I can connect it to the inputs ok and see the switch working on diagnostic but what in Mach needs settings for this to work?
does anyone have experience of this?
thanks,
11-01-2016 #3
Do you mean you want to Halt XYZ from Homing until A axis finished Homing.?
If so then this is very easy all you need to do is change the Homing script. By default Mach starts with Z then Y then X then A.
To change then goto Operator menu and choose Edit Button Script. On the Screen the Ref All Home button will flash. Click on it and it will open the script editor.
Now move the line that says "DoButton( 25 )" to the top of the list. The sequence will then be A, Z, Y, X. The other axis won't move until the A axis finish.Last edited by JAZZCNC; 11-01-2016 at 02:24 PM.
Parallel ports problems
By Cnc many in forum Computer HardwareReplies: 28Last Post: 16-12-2015, 01:59 AM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
problems with mach or windows
By johngoodrich in forum Computer SoftwareReplies: 2Last Post: 02-03-2012, 07:23 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
