Provided you seal very well then yes with Low qty mist then yes Ply will be fine. Problem then comes from your Spoil board. Even Low volume Mist still creates mositure which gets into spoil board which isn't sealed. Often MDF is used for spoil board because it's cheap.
Really if your planning on using any wet kind lube often, even with air, then you'll want something that's resonably stable.
Depths are usually a multiple of sheet sizes so 18 or 25mm etc.
27-01-2016 #2
I had a resin impregnated board on the floor of my trailer. It seemed indestructible. I was wondering if that would make a good base as it is waterproof.
08-01-2016 #3
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
