10-11-2016 #141
Yea I can second that, Chalon are just down the road to me in Haydock and as Neil says great service all round, I selected these RT18's for an up coming CAB build too and they look to be just the job, they also have an Chalon-Components-Ltd eBay Shop, as you would expect though things cost more there, like the fuse's for these holders :).
Hi guys. sorry for not keeping this log up to date (as progress has been on/off without much of a plan!!) but with all the help/support, finally managed to get this lump of steel moving!!
https://www.youtube.com/watch?v=DxSn...ature=youtu.be
Its quite a bit better than my first official cut, which was accidentally plunging 5mm into the bed whilst doing an "air cut". I guess if your as daft as me, the starting test should be "air cut WITH NO TOOL, ESPECIALLY NOT A BOTTOM CLEARING BIT!!"
Attachment 20497
Thank you everyone that helped, especially Dean and Clive for all of their patience! and again Dean for helping me out with the mounts and providing the code for the above
Next lot of tasks include:
- Building an enclosure/some sort of extraction to prevent this happening every run:
Attachment 20498
- Maybe filling this thing with sand as when you guys say the machine "starts walking", I always thought you were joking...but to my suprise it actually does!! X axis had just randomly stalled and when looking around, I saw the machine had "walked" back few inches and was rubbing the pulley against the wall!!
Attachment 20499Last edited by examorph; 16-10-2017 at 02:56 PM.
30-01-2017 #143
Hi guys, was wondering if you could help me out with compressors again please? As my old one is not going to be fit for longer term usage (ie, more than a day
), I was looking into getting a new one. This is the one i'm looking at from a local warehouse: https://www.jtf.com/air-compressor-50l-2hp.html
Reason being, it's covered by a years guarantee so won't be as bad if it does overheat. I know the specs are limited, but in general, what do you think? Suitable for CNC chip clearance? Cheers.
30-01-2017 #144
Ok but noisy. If noise matters i would go for a piston pump and belt drive motor
The Following User Says Thank You to Davek0974 For This Useful Post:
19-10-2023 #145
Bit of a bump - friend has just acquired this machine but having issues with seeing the images in this thread - Lee, don't suppose you're able to take a look?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
