Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
  1. #111
    Thanks for all the help guys, this makes things so much more clear! If I understand this right, would using terminals FB & FC have the same result for 250VAC? Sorry if its a daft question as i'm clueless when it comes to electronics!!
    Please if you get the chance could you give the updated schematics a final once over? Only additional thing I changed further to the suggestions was earthing the Spindle to the VFD rather than star point as I guess will make wiring easier.
    I noticed that AliExpress have a sale going on Friday, so would I be OK going ahead and buying the below whilst the deals are on?
    3x - https://www.aliexpress.com/item/New-...2-5560f2d46d31
    1x - https://www.aliexpress.com/item/Wate...a-7162575c4107
    I already have a 80mm spindle clamp but sale price seems to beat all eBay offers I can find for just the spindle/VFD alone
    Schematics
    Last edited by examorph; 09-12-2016 at 01:08 AM. Reason: Updated schematics to prevent confusion
  2. #112
    Quote Originally Posted by examorph View Post
    Thanks for all the help guys, this makes things so much more clear! If I understand this right, would using terminals KA & KB on the VFD have the same result? And if I used FB & FC, the same could be done for 250VAC? Sorry if its a daft question as i'm clueless when it comes to electronics!!
    While the manual mentions KA & KB I think you'll find there isn't any terminals with those markings. Well not on any I've fitted anyways.
    The manual is confusing and I think wrong. On most I've fitted FB is Common and FA =NO with FC=NC manual shows it other way round I think.
    The 3A/240Vac 3A/30Vdc are the ratings of both contacts and not for one set like what manual leads you to think.
    Just wire it like shown and it will work.
  3. #113
    They seem fine to me make sure the VFD is the one in the picture as sometimes they send a different one out.
  4. The Following User Says Thank You to Clive S For This Useful Post:
  5. #114
    Ok few small details.
    The Green wire you have coming off Stepper B (-) I'm hoping is representing Shield going to earth and your not actually taking B(-) to earth.? If correct still only earth at the Controller end not the Stepper end.
    Don't need 24V to outputs 0-3 because your not using any. Your only using the onboard Relay which is output 4 and doesn't need 24V.
    Fans can get away with sharing fuse. I use 2 x 12v wired in series because are cheaper and easier to find.
    With the 24V for Controller I/O save your self some wire and jumper between the Pins. Don't need to run separate wire to each pin. (See pic)
    Don't forget to send Earth to Machine Frame.
  6. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
  7. #115
    Attachment 19570
    http://m.ebay.co.uk/itm/170746857178
    £180
    Lee that looks to me to be the cheaper VFD
  9. #117
    Yes it will the the same like i got, how Dean said not original huanyang..
    Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
  10. #118
    But still usable nonetheless
  11. Everyone loves a cheap copy of a cheap Chinese drive! What a mine field! What do you guys think of these: https://www.ebay.co.uk/itm/131841763367
  12. 2.2kw is £222
  1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
