27-01-2016 #13
Going back to your sketch in post#19, I would extend the side pieces forward so it matches up along the whole side of the X bearing plate. You can then pickup another bolting point on the front X bearing between the 4off vertical bolts for the X bearing.
This side piece extension would be triangular in shape and fill in from the top of the gantry down to the end of the X bearing plate.
It would then (optionally) be triangular back out to the ballnut mounting point, or just go straight back.
This would provide much more support for the gantry onto the bearings for not much effort (apart from a bit more material).
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
