    Thanks Davek, I will be using a Mig welder for this. Should have the steel in this week and welding started this weekend.
    Will tack up the entire frame and gantry assembly first and check if its all square, once OK I will fully weld/stitch where needed whilst baring in mind contraction.
    Is epoxy leveling recommended for a build this size?
    The chances of it being square when done are slim, treat it as sections and concentrate on getting each section as perfect as possible, whatever method you use there should be a method of tweaking the fit later - my plasma table is 1500 square, it is made up of two side frames bolted together with cross-tubes - i could shim the joints as needed which wasn't in the end but handy still.
    The plasma was built in 2mm box section but carefully braced where needed to gain rigidity. I used about 21v / 140A and 0.8mm wire with a tri-mix gas (hobbyweld5) you need to get hot and fast, don't run the power low because it might warp.
    Cant help with epoxy, never used it I'm afraid.
    Hi guys, came home to find that the linear components had arrived today!! Woohoo
    Attachment 17739Attachment 17740Attachment 17741Attachment 17742Attachment 17743
    Seems to be great quality and Fred was a great help, excellent service and I understand now what you all mean by him being a great guy. Will keep these to a side until I get the epoxy and aluminium sorted. Blackburns offered 5754 as the nearest grade to MIC6 and quoted me £85 for 500 x 500 x 20 plate, is 5754 a suitable grade?
    Also, steel arrived earlier this week so will be welding this weekend and hopefully have a frame/gantry setup soon.
    Steel box section and plate had arrived earlier on in the week:
    Attachment 17758Attachment 17757
    Ended up buying a tungsten carbide blade for £80 to cut this as 5 of the 6 local suppliers I visited advised that the machine had a "non-standard" 25.4mm shaft.
    Seemed to work fine the first day but when trying to cut the box section the next day, it seemed to require a lot more time/force, I think I may be cutting too fast and wearing out the blade.
    Attachment 17759
    Ended up with a bit extra 100x50 section and too little 50x50 section, I underestimated how much box section it would require and assumed I had more than enough at 7.5m of each. Guess its true what they say about assuming!! Requested price for 1m more of each and changed the design slightly to use the larger box section for the horizontal bracing:
    Attachment 17760
    Other than the two sections I am ordering, all box section has been cut, but unsure if some of it is still good as I think maybe 3 sections (bed supports and gantry box section) are 3-5mm shorter than what I needed, will this be OK filling up with weld?
    Attachment 17761
    Was hoping to have it all welded up this week but ended up being a slow start with the few hick ups pushing things back a week
    All in all, it was a good experience and even though I had some problems, I enjoyed it and learnt a lot of new things
    Some questions I hope you guys could help me with please:
    • From what I understand 5754 aluminium is the grade but if specified as tooling plate, would this be OK for use on the Z-Axis without having to face it off?
    • As this machine will be moved 3 times (welded in workshop, epoxy leveled in a smaller room for heating and installed in a shed) is it worth welding some adjustable feet to the legs?
    Hi
    I don't think you will be able to bridge 5mm with weld, if you had say five joints you could maybe bridge 1mm on each, better to make the frame fit what you have now, or maybe weld in a 5mm spacer plate somewhere. Done properly this could work.
    Yes machined aluminium tooling plate is very good and ideal to use as-is.
    Yes, fit heavy adjustable feet, always useful, but not the weedy ones with M8 threads ;)
    Quote Originally Posted by examorph View Post
    You'll be putting a tremendous amount of heat into the steel if you try to fill it. Why don't you do as Dave says and put a spacer, or cut a bit more off and weld a plate onto each end?
    • Yes tooling plate is the thing to go for, needs no surfacing.
  7. Definately, M12 are the ones to go for.
    I was looking at your design just now and can see a potential problem for you mounting your ballscrew nuts on the longest axis (X or Y depending on what you call it!!). You've got them bolted from the back, how are you going to tighten them after adjusting them when fitting the ballscrews? You might also want to do the same for the gantry one as although you might be able to get to it from the top there will be a pulley in the way. I did exactly the same thing and had to change my ball nut housings so you can bolt from the outside, just a thought
Neil...
Build log...here
Reply With Quote Reply With Quote
  • #7
    Thanks guys, will get some adjustable feet sorted (>=M12) and also cut out some 50x50x10mm steel plate to weld to the frame legs for this. Will also make adjustments where I can to reduce the 5mm gap on the steel box section.
    njhussey - Thanks for spotting that. The clearance behind the plate is 10mm, think I could get away with using hex heads and tightening them up with a spanner?
    Attachment 17769Attachment 17768
  • #8
    Been a nightmare finding a local supplier that does box section without a 7.5mtr minimum order charge, but got one eventually who can do me some off cuts at a 3mm wall for a good deal.
    Will the 3mm wall thickness box section be OK for the bed support beams and horizontal supports shown below in green? Will it also be OK to weld?
    Attachment 17786
  • Thread Information
    1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
      By Scott Damman in forum DIY Router Build Logs
      Last Post: 18-01-2017, 06:36 PM
    2. BUILD LOG: New Build, Aluminium Frame Router/Mill
      By Davek0974 in forum DIY Router Build Logs
      Last Post: 31-08-2016, 05:28 PM
    3. BUILD LOG: Steel frame cnc router design/build
    4. BUILD LOG: First steel diy CNC router build
    5. BUILD LOG: 7' X 4' Steel frame build
