04-03-2016 #17
Thanks guys, to confirm, it's just the green bits in the last post its being used for (2x bed supports and some braces).
Only place it needs to be tapped is on the bed supports, so that I can bolt down the ply wood bed onto there. Any options for this with the 3mm box section? Maybe drill through and use a nut/bolt setup?
BUILD LOG: First Build 5 x 12 Steel Frame CNC router
By Scott Damman in forum DIY Router Build LogsReplies: 104Last Post: 18-01-2017, 06:36 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
