    Quote Originally Posted by examorph View Post
    Thanks guys, to confirm, it's just the green bits in the last post its being used for (2x bed supports and some braces).
    Only place it needs to be tapped is on the bed supports, so that I can bolt down the ply wood bed onto there. Any options for this with the 3mm box section? Maybe drill through and use a nut/bolt setup?
    You don't say what size bolts you want to use. If you drill through the box without a spacer in the box you have the chance of squashing the box of course you could use self tappers.
    If the bolts are near the ends of the tubes, get in there first and weld in a reinforcement plate - a lump of 6mm etc welded in from the end would work.
    If not then there are very few options really, you could drill a larger hole opposite the bolts so you can pass a socket and nut through to the front but that will only give you strength of the front 3mm section on the bolt, i doubt the hole will make any difference to the beam strength.
  1. BUILD LOG: First Build 5 x 12 Steel Frame CNC router
    By Scott Damman in forum DIY Router Build Logs
    Last Post: 18-01-2017, 06:36 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel frame cnc router design/build
  4. BUILD LOG: First steel diy CNC router build
  5. BUILD LOG: 7' X 4' Steel frame build
